disable cfm segment frame-loss measurement mep
This stops the transmission for both continuous and on-demand mode.
disable cfm segment frame-loss measurement segment_name mep mep_id
Description
This command stops the transmission of the LMM frames for a particular cfm segment.
Syntax Description
segment_name
An alpha numeric string identifying the segment name.
Default
N/A.
Usage Guidelines
This below command stops the transmission of the LMM frames for a particular cfm segment. This stops the transmission for both continuous and on-demand mode.
disable cfm segment cs2 frame-loss measurement mep 3
This command was first available in ExtremeXOS 15.1.
Platform Availability
